Scott Lumen eRide 910 customized
Tomoooo
14
8
Slovakia
upgrades:
DT Swiss XMC1501 carbon wheels
Vittoria Agarro 29x2.35 tires
Syncros Hixon integrated carbon handlebars
Shimano Saint Brakes
Wolftooth 32t chainring
Sram XX carbon cranks
Sram GX AXS Transmission deraileur
Sram XX cassette and chain
Sram AXS Reverb dropper
SQ lab 60x infinergy seat
DT swiss fork remote
Ergon GE grips
Shimano XTR pedals
Sly07
13
France
upgrades:
DT swiss dropper and fork remote
Ergon GE grips
Shimano XTR pedals
View attachment 131786 View attachment 131788 View attachment 131789 View attachment 131790
Nice,
Weight with pédals ?
Marcelfacd
75
42
Leersum
While upgrading, did you remove the motor and battery? I want to replace the brakes but guess I have to remove motor and battery. The hose is very tight and won't move along the battery.
Tomoooo
14
8
Slovakia
I had to remove the motor and also disassemble the rear triangle, there is such a small gap in the main triangle that I was not able to guide hose through it when rear triangle was joined. But that was maybe just me 😁
No need to remove battery. But headset and motor definitely have to be removed
(Ignore the stickers on the table 😂😂, used a table my niece decorated)
Tomoooo
14
8
Slovakia
Also maybe to note, at the time when I was replacing the brake hose, I did not have in the down tube dropper and shifting cables as I am running AXS dropper and shifting, so maybe because of that there was more room.
Also the brake hose is at the bottom of the frame attached to the frame with a zip tie.
Tomoooo
14
8
Slovakia
No need, you pull out the whole motor, you can even leave the cranks there. There is no need to even disconnect the motor. You just put it aside and be careful not to drop it.
Marcelfacd
75
42
Leersum
I did my upgrades and modifications now as well but wondering....what torque is needed for the motor bolts? Can't find them anywhere, my guess would be about 15 or 20Nm but maybe you know?
529K
