Riding the 22/23 Intense Tazer MX carbon
Motor
Shimano EP8 (800) 85 Nm
Battery
504 Wh
Fork Travel
170 mm
Rear Travel
155 mm
Weight
sub 24 kg without pedals, rear fender and tubes
Price
€7.499
The Tazer MX carbon is the latest emtb from Intense. Some might say this isn’t new, but you’d be wrong, and you’d be right. See our video review of the bike or keep on reading below.
The Intense Tazer MX is based on the original 2019 frame. When the Tazer was designed, the only internal Shimano battery, the BT-E8020, was a big brick. I thought it was a good idea doing what Intense and Pivot did. They used the lighter Shimano external battery and hid it inside the frame. Sure, the downtube has a belly at the lower half, but the bikes running the internal battery had chunky downtubes too.
The 2022 Intense Tazer MX, it's the same bike for 2023 but with different colors.
A 500 Wh battery in 2023?​
There are many bikes with smaller batteries these days, but they’re all lightweight emtbs. Full power emtbs usually are at 630-750 Wh. At sub 24 kg with a 85 Nm Shomano EP8 (800) motor, the Intese Tazer MX doesn’t belong to the lightweight category. Still, it’s surprisingly lightweight for what it is. The main reason Intense can build a relatively long travel dual crown bike is the battery. At about 2.5 kg, it’s more than a kilo less than a 630 Wh battery. This battery saves both weight and cost. And it’s easily removable.
Shimano BT-E8010 504 Wh external battery integrated in the downtube
The battery comes with a key and a strap to easily pull it out of the frame.
The Shimano EP8 (800) makes for a silent ride​
Running the old battery, Intense had to go with the first generation EP8 motor. The new EP8 (801) requires newer batteries with the gen2 BMS. But it’s not a big deal, the EP800 has turned into a very pleasant motor. Some months ago, Shimano upgraded the internals of the motor to reduce motor rattle that could be heard while coasting. We didn’t notice much noise when riding this bike. See our review for more info on the motor.
Geometry​
We rode the Tazer MX in size L/XL. The Tazer is usually available in 4 sizes, but the MX version only comes in two. At 181 cm I was wondering if the smaller S/M frame would be a better fit for our trails. The L/XL is a big bike with a 1.294 mm wheelbase. But riding the bike, the sizing felt fine. 450 mm chainstays isn’t very long, considering this is a downhill oriented bike.
Frame geometry
2 sizes only
The headtube angle is listed at 64.5*, the same as the regular Tazer. That’s a bit strange as this bike has got a 170 mm travel fork, 10 more than the Tazer. Is the fork axle-to-crown length very short? Or could the head angle be closer to 64*? Regardless, it’s a fine number for such a bike.
The seat tube is sufficiently steep at a little under 75*. The relatively straight seat tube ensures the angle remains steep as the seat is raised. A 505 mm reach seems a lot, but there is very little offset between the fork steerer tube and the handlebars. What I’d normally refer to as a very short stem. So the distance between the saddle and handlebars isn’t as long as one would think.
A short stem and a Shimano display.
Specs​
As you’ve gathered by now, this bike has a dual crown fork, an Öhlins 38 Race. The coil shock is Öhlins too, a TTX22M. The eThirteen wheels are fitted with Maxxis Minion DHR ll EXO+ rubber. We get a well-functioning Shimano SLX 12s drivetrain, and we get Magura MT7 brakes. This bike is listed at €7.499 (U$ 8.990). For that you get it all but a big battery. Is it a good price? I don’t know, I’m having trouble keeping up with the prices in other markets. In Norway, it’s very competitively priced.
Components
Motor system
An MX?​
Intense wanted the Tazer MX to resemble a Moto Cross bike. And they succeeded. The dual crown fork and the mullet wheels. And even a front plate over the forks. Yeah, I don’t know what it’s called. It reminds me of an MX, which I have never ridden.
The Tazer MX is MX
Riding our local trails​
This is early season around here. The more exposed and steep trails are still covered in snow. So, we did a lot of slow speed riding. Climbing with the Tazer MX was a breeze, it climbs as well as most emtbs. The only time we noticed we were riding a DH bike was when track standing and turning the handlebars to shift the balance. The handlebars can’t be turned much due to the forks overlapping the front end of the frame. That’s to be expected with such a fork.
Speeding up
Riding flatter trails at moderate speeds, this is of course not the most inspiring ride. But it’s not bad either. The bike is very lightweight for what it is, making it fine for our forest trails. And when adding a bit of speed, we had a good time in our neck of the woods.
We had to seek out some longer descents too, this is what this bike is all about. Even though this bike has DH forks, it’s not a full-fledged DH bike. With 38 mm stanctions and 170 mm travel, this by no means big and bulky for a DH fork. And I think that’s a good choice of forks.
A gnarly section
Trading attitude for speed, the front end felt so precise and sure footed. Front end stability was in a different league compared to 36 mm single crown bike we brought along. We rode narrow trails at decent speeds and the confidence we had riding the Tazer MX was at a different level compared to what we usually ride. And this sub 24 kg bike didn’t object when braking hard to do rapidly approaching, tight turns.
We also brought the bike to a very small and flat kids bike park. It was not the perfect tool for the job, the long wheelbase made the turns on the skinnies a challenge. And it’s a bit of a hassle on the pump tracks. Yeah, this really goes without saying. We wouldn’t have brought the bike here if it weren’t for the jumps. With a bit of speed, this big bike cleared them all. This really is playful for a dual crown bike.
Not too much work.
My thoughts​
The looks of this bike might be odd. We never noticed while riding though. And the upside of going with this lightweight 500 Wh is noticeable. The Tazer MX isn’t a heavy and bulky DH bike. It’s one of the more lightweight long travel emtbs we’ve ridden. And it was a great ride. Sure, the limited steering angle can be a bit of a compromise for a trail bike. But if your trails are fast and steep, it a compromise I’d take.
2022 Intense Tazer MX Carbon
We ensure you, it's a bike park.
Needs a bit of speed.
About author
knut7
Started mountainbiking in the 90s. Moved to emtbs in 2014 and have been reviewing them since 2016. Contact me here https://emtb.no/contact/
Comments
"Intense wanted the Tazer MX to resemble a Moto Cross bike"
Well that is a good idea in US with their friendly relationship between mtb and e-mtb world :- )
It arrived late 2022, so new enough I thought. The alloy hasn't arrived here yet, should be close.
I'm finding it hard to agree that 155 rear and triple clamp front is a good idea.
Now if it was 180 rear, 200 front then yes.
They should have slapped a single crown on there.
Ps there are some significant access issues a e hatred in the US. Making an ebike look more like a moto is a bad,bad idea.
This is a double fail as far as I'm concerned.
I think we should have a clear line between MX and emtb. But I think more and more people know the difference as the ebikes are getting more common. So I guess it is of less importance than it used to be. Perhaps with the exceptoin of the US!?? And, agree or not, it makes sense from Intense's point of view to make an emtb aimed at their core MX customer base.
The Tazer MX isn't really a DH bike, so I'm fine with the shorter travel. Sure, it's aimed at a narrow segment, but the bike makes more sense to me after having ridden it.
I guess the alloy MX will be more appealing to many of us.
Great point. In the states it is a good marketing idea but elsewhere i can see the issue. Even some states in the US May take issue in gov parks
It was sadly sarcastic note from me. One thing I noticed by reading Pinkbike, MTBR,etc.. is the amount of vitriol for e-mtbikers in the USA from fellow MTBers, esp. since majority of trails are illegal on e-mtb (and then there;s the whole access issue between mtb, hikers, equestrians,etc..). There is no such thing in Europe at all.
So trying to make the MTB stand out as E-MTB so strongly will make it rather unpopular choice in all the regions of US where the fight between groups go on, like in California, etc..
In Europe this is non-issue. The thing is no more obvious than some of the Haibikes. It will generate weird looks and funny comments but no vitriol.
And it's just poor design choice. If it already looks like motocross, why does it have battery of Light-weight e-bike? It doesn't jive, it's big but doesn't have big battery. Just strange.
Pretty much exactly what Plummet said as well. This bike has massive body to look like Moto, has tripple clamp fork, but not amount of travel nor battery. To warrant the weird look, it should have parameters of something like Pole Voima at least.
I have a 21 Tazer MX and absolutely love it. Most people assume its a downhill oriented bike because of the dual crown but really its an excellent do it all bike. I pulled the front number plate off and now most people don't even notice it's a dual crown. I had a 'standard' tazer pro with the E8000 and upgraded to this for the new motor and component upgrade and it blows it away. The Ohlins suspension is flat out amazing and the bike is super nimble but still bombs down anything you can throw at it. The battery hasn't been an issue for me but I'm not the guy that wants to go on some 50 mile journey. I want a few hours of fun with my buddies and ride all kinds of terrain. The fact you can swap the battery so easily too makes it almost a non-issue for most people and no doubt the way they place the battery it really helps the handling. I've ridden buddies bikes with giant 900wh batteries and you can really feel the weight as it goes up much further in the down tube. I'd take a smaller, easily changed battery every day over those things. Something like a 625 would be a good compromise though.
I have a Tazer MX Pro. Out of all my bikes, this bike is the one I look forward to riding the most. The bike is 100% carbon, frame and triangle. It is light...this is not a heavy bike at all. It handles awesome and seems very rigid up front thanks to the DC fork...which I like. The brakes and suspension are top notch. I have yet to bottom it out. This is NOT a DH bike. This is for aggressive trail or enduro riding in my opinion. I ride wooded single tracks in the Mid West and really dig this bike. There is almost nothing you need to upgrade with this bike...it comes properly built right from Intense. As far as looks, I always liked it. It has a very distinctive appearance. You won't confuse this with any other bike on the trail...ever.
