Levo Gen 3 You can route the rear brake cable down the drive side on an alloy frame.
Dave_B
1,467
1,593
Newquay
I was rebuilding the bike today and had a new rear hose so I did a bit of experimenting to see if it will route down the drive side. It does.
I think only possible if you have an AXS dropper.
I used the dropper routing for the rear brake hose, looped it over the motor and into the rear swing arm.
There is plenty of space above the motor, so no risk of crushing the hose.
You can then route the remote cable to the drive side and then up though a hole between the top tube and down tube and connect it into the TCU.
554K
