Yamaha (Giant SyncDrive Pro2) PW-X3 error code
hokkane4
52
27
Finland
Hi, my Giant Reign has started throwing some errors. Now this has happened 3 times (bike has now around 400km). Basically Motor just stops and the control panel/display starts blinking the 2nd LED in red. Based on manual and Giant app, it means there is a problem in the motor. I need to go to Giant dealer to get this clarified. But as I can still ride the bike I have not been hurrying with it. Until now, the power cycle has been enough to recover the problem.
Does anyone else have a similar experience, and how Giant/Yamaha fixed the issue? New motor?
Iansgiant
Nottingham
Same with mine
Iansgiant
Nottingham
Any joy ?
Speed10689
Brisbane, Australia
I have had this very same issue. After running a diagnostic test Giant Australia decided to replace the motor to solve it. Unfortunately I had to wait 10 weeks for a new PW-X3 motor to arrive. Had it fitted, went for a total of only three rides with everything operating as it should, and then boom... had the same issue again. Another diagnostic test later revealed the identical issue to exist. I questioned if it was was perhaps not a motor related issue however Giant were adamant the diagnostic testing was correct and are once again replacing the motor however this time with the new PW-XM motor rather than another PW-X3 model. While waiting for the third motor to arrive Giant replaced the Y harness to check just in case. It made no difference so it's not a wiring related issue. I'm due to get the bike back next week. Shall post again with a result. If the news isn't positive keep an eye on the classifieds for a 2024 Trance X Advanced E+1 going cheap.
Norbert
Gyöngyös
Nekem is volt ez a probléma. A diagnosztikai teszt elvégzése után a Giant Australia úgy döntött, hogy kicseréli a motort, hogy megoldja a problémát. Sajnos 10 hetet kellett várnom az új PW-X3 motorra. Ha felszerelték volna, összesen csak három kört ment, minden úgy működött, ahogy kell, aztán bumm... ismét ugyanaz a probléma. Később egy másik diagnosztikai teszt feltárta, hogy ugyanaz a probléma létezik. Megkérdeztem, hogy ez talán nem motorral kapcsolatos probléma, de a Giant határozottan kitartott a diagnosztikai tesztek helyességéről, és ismét lecserélik a motort, ezúttal azonban az új PW-XM motorra, nem egy másik PW-X3 modellre. A harmadik motor érkezésére várva a Giant kicserélte az Y kábelköteget, hogy minden esetre ellenőrizze. Ez nem változott, tehát nem vezetékezési probléma. Jövő héten vissza kell hoznom a biciklit. Újra közzéteszem eredménnyel. Ha a hírek nem pozitívak, figyelje a 2024-es Trance X Advanced E+1 olcsón megjelenő apróhirdetéseit.
Szia, ugyanígy jártam én is, motorcserét kaptam, de 3 hetes az EMBT, nagyon csalódtam benne, teljes kerékpár cserét kértem, de motor cserét ajánlották fel.
553K
