FOG
The contact on my E8000 motor for the wire from the display appears to be faulty. If you have to unplug to drop the motor it won't work when reconnected. If you waggle the plug it will make a contact but the slightest movement causes it to disconnect. I have replaced the wire and cleaned the motor contact but no improvement. What's the problem and what can I do about it?
