Will Hope Pro 4 hubs fit the GIANT Stance 2?
MrMarzocchi
201
181
Wales
After a rear hub for my giant (21) want them clicks ?‍♂️ do I need an eBike rear hub? It says on the spec sheet that the rear hub is 141mm, there's a 142mm rear hoep pro 4 hub, is this the right one? Thanks
slomtbr
130
98
US
142mm is a thru-axle width. 141 is a quick-release width. Hope does have QR adapters for their hubs, but you'd have to contact them regarding the width.
Paulquattro
2,299
1,276
The Darkside
Standard Hub Specs below Front first Rear last obviously ,
Theres also 150 DH rear but no such thing as far as i know in 141mm
Quick-release100mm × 9mm135mm × 10mm
Non-Boost thru-axle100mm × 15/20mm142mm × 12mm
Boost thru-axle110mm × 15/20mm148 × 12mm
Superboost thru-axle110mm × 15/20mm157mm × 12mm
MrMarzocchi
201
181
Wales
Got to get a conversion kit pal - 148 > 141mm
552K
