Haveland
Why does Specialized not use the e rated 36 or 38 fox forks on their Levos? Asking because thinking of upgrading my 36 to a grip2 but wondering about getting a 36e which I hear is an excellent upgrade on other eMTBs.
The main weight difference is sitting on the bike, where easy +/-20kg are real. The e bike +5kg is nothing. I guess all that is just Business driven marketing.Guess they go by the weight more than the e
Rise is, iirc, considered light enough not to require e parts. Although I’d check that and the 38 is unsuitable anyway
[Emtb obtuse mode on ] surprised you’d notice flattening a car on that tank [emtb obtuse mode off]There is very little difference between a ebike tune and a normal bike tune apart from accounting for the extra weight in a ebike, I've had both on my levo and never noticed any difference whatsoever
You've not ridden one have you! Or if you did you were wearing clogs and boxing gloves with an arm chair saddleThe main weight difference is sitting on the bike, where easy +/-20kg are real. The e bike +5kg is nothing. I guess all that is just Business driven marketing.
More weight would need less damping restriction to achieve the same rude quality ? No ?
As I suspectedI have 38's on my turbo levo, my friend has E-38's on his levo, after riding both bikes back to back on the same trails I can say there is absolutely no noticeable difference what so ever, any one that claims they can tell a difference are talking rubbish, it's a marketing gimmick nothing more nothing less.
The Fox E rating uses lighter compression damping stack.
Perhaps somebody in the bikeindustry defined that E-Bikes are more comfort-oriented and not performance/speed-oriented than normal Enduro Bikers
You compare the tunes on ridefox.com
Interestingly Speci doesn't use the E-configuration in fork but uses a custom RX Tune in the X2 Rearshock for the Levo. This tune is one more tick lighter/softer than the FOX "Low Tune" regarding their shim config drawings.
Best regards,
Chris
E-Fox 38, thicker compression shims. less shim qty but in sum more overall stiffness
Normal FOX38
Plus 1. System weight for my mate on his full fat e-bike is less than for me on my non-e-bike (He's a small tacker and at least 15kg lighter than me). Why does he need a special fork??The main weight difference is sitting on the bike, where easy +/-20kg are real. The e bike +5kg is nothing. I guess all that is just Business driven marketing.
