Levo Gen 2 Wheel size settings
beerglass
42
11
Bristol
Hi all
What is the wheels settings for the Levo 2020 when running a 27.5 wheel
I had a new TCU fitted and not sure the wheel size has changed back to 29er mode. I know when running a 27.5 wheel you need to change the wheel size because its slower until changed
Currently its set to 2255mm, should it be 2000mm or something ?
Since having the TCU changed it does feel slightly slow and wondering if i'm losing that 1.2mph top end
salko
1,279
872
SLO
Why don't you just measure the circumference of the wheel?
Pyr0
539
394
Wirral, UK
Did nobody learn about pi in school? :rolleyes:
After calculating the circumference from the diameter, it's a simple unit conversion from inches to mm
560K
