What happens if you run a 27.5" speed calibration on 29er wheels
2WheelsNot4
917
711
As in you calibrate it for 27.5" wheels, but instead of fitting 27.5" wheels, you keep the 29ers on it.
Do you go faster ?
I would think the sensor setting would measure the 29er or 27.5er as diameter, revolutions etc to calculate the speed. X number of times the magnet passes the sensor type of thing, as not all are linked into the phone/bluetooth GPS. So it has to measure its speed somehow.
Brent8275
45
24
Auckland
You'll go faster, however the speedo will be incorrect (shimano has a correction factor you can apply to the display to adjust this however)
I suspect that mine is calibrated for 29 but I only have a 27. 5 so my max assistance true GPS speed is just over 28km/hr.
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
Assistance will stop sooner. You will
+ or - 5%. Note; it only changes the displayed speed by -5 or +5%. If you choose -5% assistance will stop at 23.75km/h (if limited to 25km/h). This change won't be reflected in the logged speeds and distances etc.
Also the odometer will be out of whack with the 29" wheels - it will record less km than those travelled. Only an issue if you use the odo for service intervals (as I do). An equation could be easily figured out to find what the real distance travelled is, although my bike is not correct anyway - it records faster than I'm actually going and therefore also records more kms travelled.
551K
