Steelyglint
Hi all, I have Cube reaction hybrid race 750 2023 model that the nut which secures the chainring has come loose on. The bike has done about 600 miles but not sure how long it's been loose. I only spotted it as I was cleaning the bike more thoroughly than usual. The internal splines on the chainring now seem quite damaged, now pointy and sharp so I think a replacement would be a good idea. ( The motor shaft spline seems ok, must be harder) Does anyone know what oem part will fit? It's black, 38 teeth and has 5 equispaced bolt holes for the plastic chain guard. When I take the chain ring off it's one piece (no spider) and there is a separate spacer ring / washer that sits behind it but no o-ring. Its a Bosch cx gen 4 I believe.
