What chain to use on a Specialized Levo?
Andrei
Lima, Peru
So I have a 2019 Specialized Levo, had it since late November 2018. On my local Specialized store, they told me today that my chain was stretched by 0.5 and needed to be changed. I found it a bit expensive (maybe because they overcharge on their store). My ebike has from factory a KMC X11ET 11 speed chain, with Missing Link.
What chain do you recommend? Do I have to use ebike specific chains? Could I use any 11 speed chain with same length as the original one?
(I ride 6 days a week, mostly for commuting around town, with some jumps I find on route)
Thanks!
Andrei
Apples
134
127
Wiltshire
Thanks!
Andrei
Just out of interest how many miles have you covered ?
Tamas
483
503
Hungary/Bosnia and Herzegovina
Thanks!
Andrei
I’m using the cheapest 10€ SRAM PC1110 and get 2000km out of it before it reaches 0,75% stretch. It’s only 114 links so if it’s not enough you could get a 120 links PC1130 for 15€.
I was skeptical at first about the cheap ‘non ebike specific’ chains but they worked out great. I highly doubt that I could get 3x more life out of a 3x more expensive chain. Personally, I don’t miss the fancy coatings of the more expensive chains, I clean and lube them regularly.
Andrei
Lima, Peru
Approximately (I have to take my bike to the shop and have it scan by Specialized since the Mission Control app does not give me total mileage), 1100 km = 684 miles.
I use it around the city, jumping from ledges, running down stairs, hopping stuff, etc.
Andrei
Lima, Peru
I only ever get the cheap 120 link chains and just remove a couple of links down to 116.
Never had a problem and men’s you can swap them out more often ??
I will stretch it out more and around 0.75 I'll make the change. I'll try the SRAM PC X1, not the XX1 since I haven't seen good reviews compared to the cheaper X1.
Andrei
Lima, Peru
I think I'll have that as another option before making the purchase at 0.75, I was thinking about getting the SRAM X1 too.
Tamas
483
503
You can stretch it out to 0,75 no problems. The chain checking tools are very ‘conservative’ in my experience as most don’t factor in the roller wear and makes you change the chain too early. It’s a good business for bike shops though...
Andrei
Lima, Peru
Yeah you're right, the shops will always want to make you spend money when and where you don't need too, although there sre exceptions.
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,617
5,393
Helsinki, Finland
My very good friend, who owns a bike shop told, that you can stretch the gain out to 0,5 3 times and change just chain. No cassette change until fourth time
Andrei
Lima, Peru
Good to know, thank you. Hopefully by then I'll save up some money for a good cassette.
Xeretic
91
40
Russia
Before Levo I used cheapest SRAM 1110 chain on my fatbike and it works great. Purchased 2 SRAM 1110 chains for when my factory chain gets stretched to 0,75.
555K
