Hi, in about he last 25 miles a noise has developed in the motor area with every pedal stroke. Sounds like something g rubbing but can’t see anything. Chain guide is not rubbing. Has anyone heard of this before? Trying to figure it out. Thanks
What is the bike? On a Kenevo I had a rubber squeak when peddling, maybe a seal into motor. Some WD 40 sorted that at the bottom bracket but not sure if WD is the best stuff to use. Also I sometimes get a creak from the plastic motor housing, you can add grease in the to the plastic motor cover edges.
