Watch the seat clamp screw
highpeakrider
692
566
Peak District
My bike had a bit of a creak and while investigating the seat post screw snapped despite being torqued, might be worth a check of your bikes it looks like a cheapo one.
stiv674
777
600
Wiltshire
My bike had a bit of a creak and while investigating the seat post screw snapped despite being torqued, might be worth a check for your bikes it looks like a cheapo one.
Funny you should mention that, I altered my seat and then snapped the bolt, I ordered some stainless ones as replacements, has been fine since.
OldBean
602
528
East anglia
My Focus one did the same ...light weight alloy bolt..
Swapped to ~Stainless BUT dont over torque as next thing to go will be the clamp thread, but then a suitable nut should do the job.
9,281
That is a small issue, but one that has pissed me off more than a bit! I will be checking that when I go pick the bike up from the Focus dealer and get it replaced.
Lad
113
102
Snapped it on mine too whilst torquing it. Thought that must be just a one off dud screw...
Focus need to put a high tensile steel screw there.
highpeakrider
692
566
Peak District
Steve I think you are just pissed off at the minute, hopefully they will sort it and you can enjoy the spring and summer riding.
Lad
113
102
Wrenching on my carbon bikes I quickly learned the hard way that it is good idea to use torque wrenches, so I used one on the now infamous Focus seatpost bolt. I can tell you that it snapped waaay before recommended torque. At that moment I really thought my wrench is kaput.
highpeakrider
692
566
Peak District
Hi Phil,
just have checked into the part list of the bike.
Seems that the bolt was changed already by us - now we use another material which seems to be stonger then the first one.
Best regards,
Wilko
Multichannel Sales & Social Media
[email protected]
+49 (0)4471 966 401 745
FOCUS-BIKES.COM
motmcd
87
317
reading,pa
Good information. Thanks for the share. It may be helpful to know that stainless steels typically do not match well with aluminum. SS is reactive with aluminum, and when SS comes into contact with an aluminum base metal, the aluminum will likely corrode. SS screws are also more susceptible to galling when used with steel nuts and vice versa. A small amount of a never seize product eliminates this concern.
OldBean
602
528
East anglia
Good info.....ACF 50 or Copper grease any :unsure:good?
Trots55
7
Oxfordshire
Yep, mine did that as well. Did it before I'd even ridden the bike. I was a little cheesed off...
Bought a stainless steel one.
553K
