Wall Mount for E-MTB?
JetSedgwick
384
1,005
Lake Tahoe California
I want to create some floor space and wanted to mount my e-bike on the wall...but it's over 50 lbs, anyone have any ideas on how to best mount it to the wall?
a google search yields mounting options for regular weight bikes that are much lighter.
Tim1023
660
584
Hamburg, Germany
Steadyrack! Just brilliant. Very sturdy and easy to use. I bought this one: Mountain Bike Rack
Can cope with up to 35Kg (pretty sure that's much more than 50 lbs!!)
They talk about space to the floor when measuring, but also look at space to the ceiling if you're installing it somewhere with a low ceiling.
Also note that I was concerned with how my Levo could cope with the weight and was told no problem by the local Specialized Concept Store.
jerry
257
166
Belgium
There are some opinions that mountaing the bike vertical (with front wheel in a hook) doesn't play well with fluids (brakes, shock). I found that as well, though it was on a bike that had been hanging up for months. And putting it horizontally (hooking top tube) doesn't save much space; and it's terrible for your back :)
Tim1023
660
584
Hamburg, Germany
I heard about the oils issue, but I use my bike so often (including commuting during the winter) that I'm not concerned.
No problem with the Steadyrack and your back. As long as you can apply the rear break and walk backwards to get it on it's rear wheel, a little shove with the knee is all that's needed to get it onto the rack. See vids on their site.
thebarber
986
598
Norfeast
Mine holds up well...
NULevo
539
341
Nottingham
Steadyrack all the way, you won't regret it.
Fit it as per the instructions and it's as easy as pie to use, no back issues. As for fluids, my LBS and Spesh store advised it was a good idea to store the bike upright as it keeps the seals lubed.
There's lots of vids on YouTube, worth a look.
fenwick458
295
187
Cumbria
another vote for the steadyrack
the argument about fluids in shocks is flawed for sure, shocks are mounted upside down, horizontal or whatever way the frame designer thinks of, so surely rotating 90 degrees won't hurt them
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Not flawed. Retarded.
Mounting a bike vertically won't affect the shock at all and won't affect brakes unless they have a shit bleed in the first place
it will move damping and lower leg lubricating oil in certain forks to the top (which isn't a bad thing as it'll also lubricate your foam rings) gravity and fork movement will cycle the oil back to the bottom again.
No drama
Austin Thomas
51
69
Another vote for Steadyrack. My eBTB is 50lbs and lives happily and easily on their wall rack. So good I bought two! I still cant let the analogue bike go…
weihlac
42
35
Try a ceiling mount. With a pulley system, it is easier on your back. Mount the ceiling track on a ceiling joist.
Jul 4, 2020
36
23
Not a massively solid wall but can take over 30kg easily on a not massively solid wall. Another vote for checking how low the ceiling is, very nearly made a mess of it...
BushLevo
81
30
Melbourne, Australia
Confirmed. I have SteadyRacks for all my bikes, and a Mountain Bike version for my Turbo Levo. Works brilliantly.
554K
