Walk Assist. Or Not, as the case may be.
Doomanic
🛠️Wrecker🛠️
8,722
10,389
A video I saw recently where the bloke used walk assist to clean his chain got me thinking; what's it supposed to do on the Bosch system? He had a spring clamp on the button and the motor was clearly running as the cranks were spinning slowly. When I press the button with the bike on a maintenance stand and in top gear stand nothing happens. Is it broken?
E
EddieJ
Guest
With Purion, I believe that you have to press the walk assist button then hold down + button.
I've never had cause to use it, so that is just a guess, by trying to remember back to something that I have previously read..
In the case of Intuvia, you just press and hold the walk button.
In respect of cleaning the chain, I run two chains, and use an ultrasonic cleaner.
Doomanic
🛠️Wrecker🛠️
8,722
10,389
Sussed it. Once the walk button has been pressed you have a short time to press and hold the + button and it works. Not very intuitive, but it’s all we’ve got.
554K
