Volume spacers for Fox Float rear shock
VardyR
41
9
New Zealand
Hi
Has anyone made their own volume spacers for a Fox Float rear shock ?
Looking at machining some up but have no measurements
Any help would be appreciated
RustyIron
1,823
2,827
La Habra, California
Yeah, I've made a few. I use Delrin because it's easy to machine and it's durable. The OEM spacers are measured in cubic inches, if I recall correctly. They also have a step in them that requires an extra operation. I make my spacers more of a cylindrical shape, and then do a rough calculation of the volume. You could measure displacement in a graduated cylinder, but that's a hassle. You don't have to make the ID really tight. Make it so it just pushes into place with little force and it will be fine.
VardyR
41
9
New Zealand
Thanks for that
I have use of a lathe so making them will be no problem I’m just looking for some dimensions to minimise the guess work
RustyIron
1,823
2,827
Got ya covered, bro. Check out the attached pics. The yellow one is OEM Fox. The white one is some kind of aftermarket. You can look up the yellow one to figure out the volume displacement. If I recall correctly, the white one is 0.3 in^3.
Yellow one:
OD = 1.530"
ID = 0.525"
slot = 0.375"
outer thickness = 0.407"
inner thickness = 0.290"
White one
OD = 1.498"
ID = 0.520"
slot = 0.362"
outer thickness = 0.348"
inner thickness = 0.241"
VardyR
41
9
New Zealand
Yellow one:
OD = 1.530"
ID = 0.525"
slot = 0.375"
White one
OD = 1.498"
ID = 0.520"
slot = 0.362"
Much appreciated Rustyiron
554K
