Using two tubes .
ari
69
29
Before i drill a second valve hole , has anyone used 2 tubes in the rear tyre/tire? im thinking 2 light weight tubes which will be lighter than a heavy duty tube filled with sealant , i am a cheap arse so it will be a cheap thing to do . Not really sure about the pressures eg 2x10psi=20psi or 2x20psi=20psi????
RustyIron
1,812
2,780
La Habra, California
Don't do two tubes. At speed, it will create harmonic vibration that causes the derailleur to jump around. What you need is an odd number of tubes. That's why one tube is so popular. If you're going to do anything, put in THREE tubes. Aside from the vibration damping, three is 50% better than two.
  • Agree
Reactions: Dax
fasterjason
107
52
You can have two identical half-sized tubes inside the same tire, but they must spin in opposite directions so that they do not violate the Pauli exclusion principle. Otherwise (at the macroscopic scale) your wheel becomes unstable and undergoes drastic volume reduction, i.e. a flat tire.
Jokes aside, I want some of what OP is smoking.
552K
