Hi All, AS above, I have ugraded to 34T from 32T, do i need to lengthen Chain?
K KrisScott1990 Member Jun 14, 2020 77 43 Edinburgh Oct 27, 2020 #1 Hi All, AS above, I have ugraded to 34T from 32T, do i need to lengthen Chain?
Mcharza E*POWAH BOSS Aug 10, 2018 2,580 5,164 Helsinki, Finland Oct 27, 2020 #2 If you have 116 links chain, I don't thinks so. But you can always check it by removing all the air from shock and test rear suspension if the chain length is correct
L Loe Rider Member Oct 26, 2020 59 30 Kernow Oct 27, 2020 #3 Nope. I went to 36 with no issues. Just check this measurement and adjust your B screw as necessary:-
