Upgrade shock
Doomanic
🛠️Wrecker🛠️
8,768
10,469
If you already have it why not give it a try? It's not a difficult job to swap the shock.
zaykay
93
81
Finland
Stock shock has the same tune than Nomad’s super deluxe rt. I would do the upgrade. Especially if you decend a lot. Rail 7’s stock shock is not that good.
Your super deluxe needs to have the standard bushing based lower eye. The model with the bearing kit does not fit. With the standard mount it should be direct swap with stock shock mounting kits.
559K
