Levo SL Gen 1 Upgrade rear shock Levo SL expert
Nesttek
Rus
Hello Forums!
Please help me out: what size bushings (shock mounting hardware) do I need for a FOX Float X2 Factory? I’m planning to switch from a FOX Float DPS on my Specialized Turbo Levo SL Expert Carbon 2020. Thanks!
Zed.
275
383
Deepest Bandit country (Wales)
Hello Forums!
Can’t you use the existing mounting hardware?
That’s what I did when fitting an Ohlins coil damper to a friend’s carbon Levo Sl👍
Nesttek
Rus
Разве вы не можете использовать имеющееся монтажное оборудование?
Именно это я и сделал, когда устанавливал демпфер Ohlins на карбоновый Levo Sl моего друга.👍
Yes , but I’d also like to buy an extra set of bushings just in case
Nesttek
Rus
I found the dimensions in several sources , + myself was also able to measure the up bushing : 8mm/22.2mm (22)
Low mount : flip chip .
Maybe someone could use it ;)
573K
