Had the same prob with that bike.
Bought a RS judy gold. Light xc fork. Nice for the money.
Easy to adjust with the air valve ??
Thanks for the recommendation.
Can I ask were u bought it from.
Yep , straight swap. See that you buy a fork with the correct axle. So your wheel fits. You need a tool to remove the crown race off the old fork. And you need a nut setter. Got them here in France from the brand Icetoolz. Together 38€. Hope this helps
Thanks GrenyYep , straight swap. See that you buy a fork with the correct axle. So your wheel fits. You need a tool to remove the crown race off the old fork. And you need a nut setter. Got them here in France from the brand Icetoolz. Together 38€. Hope this helps
Hi again Grenny
I've found a site www.purebike.fr who sell Icetoolz. Can you tell me which I need ? The bike isn't here at the moment. G.
Hi GrenyHad the same prob with that bike.
Yes it fits and I have been riding with it for a month or so but there is a slight rubbing noise......it could be that the rotor is sllghtly out of true.
The post mount on the old and new fork do look completely different spacing so thought I’d ask. G.
I have done that and loosed the caliper bolts and applied the brake ti centralise it.....a bit better but still a slight noise. I have seen “universal” post to post spacers and wonder if Cube have their own matched to the original fork?Suspend the bike , then see or rotor is out of true . Maybe the mount needs be repositioned
Yes will do......but it seems strange that the noise was inly evident after the fork change?Nope , it’s universal. Maybe rotor is not straight anymore... try to see if it’s straight
I an not back in the UK until next week so will check then.
Thanks G.
Hi Greny...do u know if these will fit on the cube hybrid reaction pro 500 ..cheers RockShox Judy Gold RL Solo Air 29" 100mm Boost 15x110mm Fork With Oneloc Remote | eBayHad the same prob with that bike.
Hi yes they will. I fitted them on mine, Cube Reaction Pro 2020.Hi Greny...do u know if these will fit on the cube hybrid reaction pro 500 ..cheers RockShox Judy Gold RL Solo Air 29" 100mm Boost 15x110mm Fork With Oneloc Remote | eBay
