H2026
Probably be a no but, I have a stereo 140 2019 black grey. It has the 500 battery, can you convert it to a 625??
You’re quite right, I’ve just had a CLOSER LOOK at dimensions, the 625 is circa 65mm longer then the 400/500.I don't think the 625 will physically fit.
I have a 2020 160 with a 625 battery, the holder mechanism has the option to be moved to fit a 500 battery. This is approx (meaning I haven't measured it) 50-70mm shorter than the 625.
I think the 2019's were designed around the 500 as the 625 wasn't available
Edit...
just measured my 625 battery and it is 425mm long
