Under shorts padded liner?
MrSimmo
1,096
1,047
The Trail.
Ok this is a weird question, or maybe not.... anyhow..
Does anyone know where I can buy padded liners for riding short/trousers?
I've tried searching and maybe im missing something but cant find any.
I've got a padded liner with my Endura MT500's (this: Endura Padded Liner Shorts | Merlin Cycles) but the leg part is too long so want a version without the legs (sort of like this but with a pad 3" Boxer Brief)
Cheers
There are some option out there, first ones that spring to mind are also from Endura who make two boxer type shorts
and
There are also these, but may be too long for you:
MrSimmo
1,096
1,047
The Trail.
and
Thanks R120, Looking at them they look great but looking for something probably half the length of the Endura's above - so really short if possible. Its a right mission :)
MrSimmo
1,096
1,047
The Trail.
Endura padded liner shorts
Thanks Steve - I have those, they came with my MT500's.
I've photoshopped the photo to show what I'm looking for (ie chopping off the leg bits), turning out to be hard!
MrSimmo
1,096
1,047
The Trail.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
ALDI and LIDL used to do exactly what you are looking for but as they were aimed at the casual cyclist wearing normal clothing over them the padding was always fairly minimal. A selection of padded undershorts with more of a Trunk/Boxer fit is usually available from Ebay and Ali Express
Padded lycra cycling short legs are almost always longer than you are looking for to avoid inner thigh chafing while pedalling. Especailly at the hem.
May we ask what your reason is for needing them so short?
MrSimmo
1,096
1,047
The Trail.
Cheers Gary ?
Its purely Ive been finding my Endura liners too tight at the base of the legs where there is a rubber type stretch ring section. I cut that bit off an older pair which made them spot on but has resulted in fraying so thought there could be a shorter alternative.
NULevo
539
341
Nottingham
Cheers Gary ?
The Endura Engineered Boxer II does not have anything on the bottom of the leg section. I have both, the one that comes with the shorts and it is tight on the leg and the rubber grip at the bottom has almost created bald patches on my thighs.
The engineered boxer does not have any form of grip at the bottom of the legs and is also shorter, best of all a much more comfortable pad as it's designed for longer rides. I'll be getting some more of them to replace the other liners I have.
MrSimmo
1,096
1,047
The Trail.
Cheers ?
552K
