Tyre wobble after going tubeless.
swampy
Done the tubeless conversion this weekend on my Etrance.
Used the Peaty's conversion kit but no need for the tape on de Etrance as tape is already fitted from factory.
Front took 15 minutes, worst part was breaking the seal to remove the tyre.
Back also took 15 minutes, and went good except for the fact that I had to remove the tyre 3 times and is still not got it perfect.
The bead seats perfectly, no leaks and the rim line is the same distance from the rim all the way round on both sides, but the tyre wobbles. The wheel has been on a jig and has less than 1mm movement.
Its like the tyre is buckled, it's a Maxxis High Roller 2 27,5X2,6. Never heard on this before until I looked it up on Youtube, but apparently it's possible if the sidewall is faulty.
Anyone else had this issue? Any remedies?
Doomanic
🛠️Wrecker🛠️
8,702
10,342
I've got the same thing on a Magic Mary. Only solution is run higher pressures.
Doomanic
🛠️Wrecker🛠️
8,702
10,342
40PSI gets rid of the wobble, under 25 and it's back. Make sure the tyre has seated on the rim properly.
MPJ
151
200
Chiltern Hills, UK
Had the same thing on a Smart Sam that came with the bike. Went tubeless, probably could have lived with it if it was on the back but being on the front I couldn't avert my gaze and nearly came a cropper a couple of times so just chucked it.
Tooks
461
557
Lincs UK
That would annoy me, but then the sound of that free hub is loud as well isn’t it!
I’m always packing mine with grease to keep it quiet.
Back to your tyre, I would want that replacing, it’s miles out if its properly seated on the rim.
DrStupid
1,464
2,128
Pleasureville Ky
It looks like the bead is not truly in seated. A trick I use for my motorcycle tires, is to spray the rim and tire with windex or other glass cleaner to act as a temporary lube to help seat the bead.
Not sure if this would contaminate the sealant or not. But, the idea behind glass cleaner, so I was told, is it evaporates leaving no residue. This was important on a motocross bike where gobs or torque would be transferred through the bead and nothing slippery should remain.
9,281
When you first installed the tyre did you pump it up to at least 40psi and maybe even as high as 60psi? You should have heard some loud bangs as the beads slipped into place. That is not just me that hears bangs on my tyres, it is a well known occurrence.
swampy
Bead is truly seated, used carwash and water and just popped into place. No leaks at all.
swampy
Heard the pops and inflated to about 30psi..then let the air out to add the sealant through the valve.
MrBrownstone
430
643
Maine
Yup bad tire. My Ardent 2.4 29 on the rear has had a wicked wobble spot since new almost 1000 miles ago haha I don’t give a shit it hooks up and rolls great! Many more miles to before she’s done.
Lad
113
102
Same here with Continental Der Baron Project 2.4" on front. Wobbles like crazy, re-seated at least 3 times, still no good.
552K
