Wheelie_King
The Spirit Level ?️
Hi All
I’m new to tubeless and have used the Muc-Off sealant recently to convert. I’d read it out performed all rivals and even sealed substantial sidewall tears.
First time I’ve had an issue tonight. Very wet and muddy UK riding conditions.
Looks like I’ve pressed the tyre against the rim and ended up with a 1-2mm hole in the edge of the tyre (still between tread so not sidewall) and next to it where the bead meets the rim some air/sealant escaping there. Both were what you’d call a slow puncture, and sealant was very slowly escaping both areas.
Trouble was neither sealed despite orienting the wheel to pool sealant in the right place, and then pumping up and riding on.
Is my sealant crap? Did the 0 degrees temperature affect the sealant? Did the muddy water prevent it sealing?
I know there’s no firm answers here but looking for the benefit of peoples’ experiences.
