Hugh-Jazz
I'm building up a custom mtb tandem frame with a steps 8000 motor. My current plan is to hold two 504WH motors external on the frame, with one being wired to the motor and other only mounted. We will swap batteries when the first one is used up. The Bosch system on the Moustache tandem can switch between two battery packs automatically to use both without having to swap. Does Shimano support a similar mulit-battery setup?
