I have a Tero X4 and like it a lot. it has always shifted fine but at 320 miles it started not shifting properly in the middle gears, say 4th thru 8th. Sometimes you shift up from 3rd to 4th and it will not upshift unless you finally shift up again then it shifts up 2 gears. It will also hesitate for periods when shifting up in other gears in the middle range. Shifting down to larger cogs seems fine.
I took it to the dealer and he said one of the middle cogs on the cassette was worn out! Spec' warranted it so the cassette and a new chain was installed. but I still have this problem. I know there is some adjustment on the derailleur and my logic tells me it needs to be adjusted to where the derailleur pushes the chain a bit more outboard when shifting up??
I've ridden bikes for years and when I shift I continue to turn the crank but back off considerably on the torque I put on the pedals. I also have a Levo I ride off road, (and it shifts flawlessly) so the Tero is not abused and mostly used on concrete bike paths near me.
I need to hit utube and educate myself better on how to adjust the derailleur but wanted to get some guidance before I do that. The bike is still under warranty but my luck would be the dealer will futz with it some more then say "it's as good as it can get". Thanks for any replies!
