Riverside
Just in the process of changing the stock Suntour forks (which have a 1 1/8" steerer and a reducer fitted) for a set of Rockshox 35 (which has a proper tapered steerer - 1 1/8" to 1 1/2"). However, using the original bearings (only 2 months old), I can't get the headset play right; either too slack or too tight. Anyone else had this problem or tried this type of upgrade? I'm starting to wonder if there is something different with this particular lower bearing and reducer setup e.g. thinner bearing....??!!??
