Morning all,
I've had some issues in past few weeks which have gone from not being able to power on every now again to completely dead. Using mission control there are no problems identified and the battery reports as 100%.
While joining the forum and waiting for access to post a request for help and after reading up on the forum about an array of power related issues, I decided to do some basic checks for water ingress. The bike has never been power washed but thought I check to see if there was any water or moisture in the key areas, TCU & Motor housing.
So now that I can post I thought I'd show what I have found, which I believe is the problem and may help others. You can see in the pictures attached, small amounts of debris round the base of the pins and scortch mark on the right.
The independent I bought the bike from, no longer sells specialized bikes and basically told me to go elsewhere (nice). So with the bike under warranty still,I'm hoping a couple of local independents will be happy to help, otherwise I have no idea what to do.
