Turbo Kenevo Comp vs Trek Rail 9 gen. 3
gabsag
Narvik, Norway
Hello.
Im joining the dark side and buying my self a emtb. I have both of these bikes on hand for roughly the same deal (£6k) and i have a hard time choosing. Both brand new.
The Kenevo is upgraded with the 700wh battery. Might eventually also set it up mullet with a new fork and wheel. The slx brakes is also a downside and will need an upgrade.
The Rail comes with a zeb (wich i prefer over the fox), ultimate shock, AXS driveline and Bosch CX performance line. Code R i can live with.
I live in northern Norway, and ride everything from hard techincal terrain to fast flow and long mountain-passes.
For refrence I have had:
- Trek Remedy: Sweet and playfull, but felt a bit under gunned.
- Trek Slash: Good, but had a size to big so felt slugish
- Commencal Meta AM 29 (current bike): Love it, and done everything from mellom trails to Lenzerhide Bikepark.
What would you choose and why? I have no experience in motors etc.
Stihldog
Handheld Power Tool
3,357
4,646
Coquitlam, BC
A deciding factor for me would be access to a LBS. In my case that would be Trek, Norco, Santa Cruze, Giant …respectively. Next would be the motor. The motors are getting better each year but I would lean towards a Bosch CX.
Welcome to the forums.
Cheers
SimonG
8
8
I have a Rail 9.8 XT Gen 4 Smart System.....Had a Levo before that.
The Rail Bosch motor is better providing grunt all the way through the cadence range, it keeps providing good support at higher speeds.
Brose pulls like a train climbing uphill in large cogs, deffo stronger than the Bosch but the support reduces at higher speeds/cadences.
Both motors are good, just different.
If you enjoy going downhill fast....Kenevo, I have ridden one and it does not want to turn in as easy as the rail on the flowing trails.
Going downhill fast - Kenevo
Mixed flow trail and hold its own going downhill - Rail
If you are derestricting - Rail........ the Brose power curve drops at higher speeds.
*I am 173cm and the sizing charts all say im a medium. I find sizing up to a large fits better and is more stable at speed.
Paulquattro
2,198
1,215
The Darkside
Cheers
Welcome and ^^^^ What he says :)
545K
