tubeless
latefordinner
32
13
Bucks
Yes , gone tubeless , pumped up , air escaping from big thorn hole in tyre :unsure: Noooooooo ! :( so cut piece from old tube, poked in hole and stuck patch on outside of tyre, job done off i went well happy with self ! :D
9,367
Whatever works to get you home, works!
But you would be even happier if you had stuck a patch on the inside of the tyre! The air pressure holds it against the tyre wall. On the outside, the air pressure will try to blow it off. And then there is all the trail debris trying to scrape it off.
I strongly advise that you address this issue before you ride too many times. :)
latefordinner
32
13
Bucks
:) agree with u there, but i had trouble getting the tyre on and although i knew the hole was there i thought it would seal its self but still good at mo !
Similar threads
554K
