Tubeless slime
16vdady
27
14
Ramsgate
So on my ride today I had my first puncture with my tubeless set up.
It was more of a small slit in the tyre than a piercing. I could see and hear the slime/air coming from the hole.
I got some air back in the tyre to ride back to the car.
Back at the car I topped the pressure back up and the slime seems to be holding the pressure.
Now my question is do I just leave be or do I need to do something else??
Jakejake
If you get a chance, whip the tyre off and repair the inside of the tyre, a bit like repairing an inner tube with a puncture repair kit. I.e. patch and vulcanising glue. No need to worry about it after that.
The plug you're on about is more something to do on the trail if a big hole won't seal. It's not permanent, although can last months.
Otherwise it'll probably be fine it the slime has sealed it, maybe a very slow deflation
10,012
@16vdady If it is a small slit, I would not trust it. Even if you have topped up the sealant as advised by @Mcharza don't forget that although sealants are excellent, they are not miracle workers!
Either do what @Jakejake says (internal patch), or plug it like others have said. There are loads of different patches you could use and you probably already have a tube patch that would work. But you have to remove the tyre and clean it up first, which is a bit of a pain. Or you take a look at plug kits and do the job without having to remove the tyre. Loads of different ones of those too!
What I would not do is to just leave it and hope for the best.
Sander23
740
458
Belgium
Ive had muc off sealant in mine. Had a small slit in my tire wich the sealant diddnt fully seal. I could put a screwdriver in the hole wich the sealant sealed but still some very tiny bubbles kept comming out. Pluged it and tire worked for another 1500km.
577K
