Ok, never really done tubeless, I've never really been bothered before. However, got my first puncture on my trance e+2. Luckily it stayed up enough for me to get home in the warm and dry to fix it. First thing, the tyre was an absolute b****d to get off! In my, ahem, 40 years of fixing punctures I've never been even close to having so much trouble with a tyre. So thinking I would have completely lost the plot if I'd had to do that out on the trails I thought I'd go tubeless for the first time as it allegedly comes with all the bits I need.
So finally having got the tyre off, first thing is the instructions do not resemble the kit they supply! So a few questions for you people more clued up than I:
I presume I don't need rim tape as it has a nice smooth plastic bit in it already?
They only gave me 3 x 59ml tyre sealant bottles in the kit so I used 1 and a half bottles per tyre, is that enough?
All I did was take out the tube, put the supplied tubeless valve in, pour the sealant into the bottom of the tyre and blow it up, is that it?
For all you UK riders, how often do you need to top up the sealant? Every 6-8 months I read somewhere?
Can I mix it with stans sealant as that is more readily available and is a lot cheaper?
I did one tyre last night as above and it's still inflated so I'm optimistic, but I haven't actually ridden on it since.
