Trek Powerfly FS9
Jmincent
Torquay
Can someone help with removing the crank on my powerfly. The crank would appear to be self extracting. Before i try more force can anyone confirm. Sorted now. Thanks
Doomanic
🛠️Wrecker🛠️
8,700
10,336
I don’t think the crank is self extracting. Mine certainly isn’t.
You need to remove the Allen bolt and then use a puller to get the crank off.
Crank off. Needs a puller.
Ice Toolz Crank Removal Tool with 8mm Hex Key - EMTB Forums
Undo lockring. Needs the tool.
IceToolz Bosch Lockring Tool - EMTB Forums
Remove o-ring, carefully.
Remove sprocket.
Clean area with stiff bristled brush.
Remove crank seal and regrease behind it.
http://www.p-f.ch/ext/vv/Lagerschutzring.pdf
Assembly is the reverse of removal[/Haynes Manual]
552K
