Nerds On Dirt MTB
Just wanted to hear from any Relay owners how they like their bike. We have sold several and had a few issue on a couple but I wanted to get a bigger scope. Also hey Rob where is that Relay vid
That is one thing that I should have mentioned that I also had to do. There were two problems when I got the Relay but both were solved within 24 hours. First ride I took to bed the brakes I realized that they were reversed off of what we expect in the US. It was not a problem when bedding but then I was testing them after and almost crashed because I wasn't expecting to hit the front brake. Obviously I was able to fix that in <5 min but if you were to ask me I would tell you that this was a far bigger QA fail than the other one.My girlfriend and I got our Relays (GX builds) we tore them both down and replaced everything but the rear shock (running them mullet). After getting hers built we found her battery will not charge (DOA waiting on Transition to get us a new one). I gave her my battery since I still have my Levo and I'm waiting on parts, and she loves it. Had to do a small bend on the battery clip so they would "click" in.
Relay Short
A quick pic of the girlfriends Relay, ready to race this weekend!
View attachment 115030 lettering on the tyre
Would look so good if you could match the wheel decals to the Transition blue!Well, other than some fork stickers and the battery (which I just need to pop by the shop and pick up) my Relay is done.
My Relay build
Yeah those wheels came off another bike and prolly as close as I could get without paying extra for custom colors.Would look so good if you could match the wheel decals to the Transition blue!
Is this your first ebike?First ride in the books. I might be the only person in history that was slower on an e-bike on the climbs than my pedal bike, but holy cow did I struggle.
Hey, get the assegai 2.5 dd or exo+ if you run cushcores, maxxterra rubber mix. You gonna love it on ebike. Also your body needs to get you to different weight distribution on ebike and you will be fine my relay should be with me next week!I'm definitely getting closer on set up and found some ebike magic today.
Basically, rode a usual, very technical spot and made my way deep down in the canyon where the best gnar is and was able to explore considerably further than I would on my pedal bike. That was awesome!
Must of my handling issues are related to poor suspension set up, which is on me. I find the rear air shock combined with the suspension progression a bit like hitting a wall off drops and such. So I removed a shock volume reducer. Also getting the fork closer, slightly raised my bars, etc.
Manuals are definitely much harder on an ebike with all the weight in the downtube but it does provide an upside: great front wheel traction! That was a nice surprise. I do suffer from less rear traction however. Currently on a DD 2.5 Aggressor with an insert and pretty low pressure. It tends to slip on it's side knobs on off camber climbs.
I'm starting to get the hang of climbing on an ebike as well. At this time, it's no advantage on my technical climbs at all because of the heavy front end.
If I can continue to get the Relay more dialed in and really begin feeling like myself on it, I'll finish my build out and sell my SJEvo. After the first ride, just selling it and going back to a bike was definitely being considered.
Basically to complete the bike I'd convert to a SRAM 11 speed that I have around here and get my rear TRICKSTUFF brake installed and it would be complete. Also need to think about tire choice in the rear to get what I need back there.
Ps. Most of the cable rattle comes from where the cables enter the frame.
Just ordered the Assagai. I needed better rear traction so why wait? ThxHey, get the assegai 2.5 dd or exo+ if you run cushcores, maxxterra rubber mix. You gonna love it on ebike. Also your body needs to get you to different weight distribution on ebike and you will be fine my relay should be with me next week!
Yah, I was trying to give some consideration for rolling resistance but probably should just do dual Assagais.
I'm barely using any battery juice btw. Only about 20% every 10 miles on very chunky steep terrain. I keep in on the Breeze setting unless I'm doing a boring smooth climb out.
I did have a moment where the lights turned out on the trail when I stopped and my Relay wouldn't turn on. Pulling the battery and reinstalling it started it right back
I use at the front assegai Exo+ but in maxxgrip compound. Killer comboJust ordered the Assagai. I needed better rear traction so why wait? Thx
Why not so great e bike ? Fazua issues ? Even after recent update ?Catching up on the thread, yeah we have experienced the weird "blinky lights bike no go" a few times too, its always after its sits for a bit. I have not connected the app to mine yet so I need to do that for sure. Glad that getting your suspension sorted your ride issues, I love how this bike feels like my Spire does but with a motor. I had a rattling as well and found that the controller cable (be sure not to tighten that too much or it starts sticking) is crazy long and the connector was just banging around inside the frame.
After swapping from 29 to 27.5 in the rear we can't find the setting to change the motor to the new wheel size (my GF has connected her app), I asked my shop manager if he knew, he did not and I pinged Transition about it, no answer, so that's a bit annoying as if its like all ther other e-bikes we have has it needs to be updated. Right now I feel its a great riding bike but not so great e-bike
