TheBob
Hi all
Picked up a new Trance X E+ a couple weeks ago. So far I am loving how it absolutely destroys the climbs. I''ve upgraded the dropper to a OneUp 180mm for some more clearance on the downs and will be fitting some spare Bontrager Line 30 carbon wheels with Rimpact inserts as soon as my new brake discs arrive. In the meantime I have been going throughthe bike, making sure all the correct bits are greased and torqued. When I removed the fork last night to check the headset bearings I found the lower headset bearing to be stuck in the headset cup. Is this right? On all my other bikes the lower headset bearing slides out with the fork, so I'm worried this is an issue.
