Trance e+2 suspension
Silato
128
73
Manchester UK
Hi.
Ive a trance e+2, was wondering when you lift the bike from the ground is it correct to have a small movement from the suspension. Appears to be from the shock.
Wondering if it needs torqueing.
Tony.OK
191
234
Napier, New Zealand
My lower shock mount bolt was becoming loose after rides and giving slight movement when lifting bike......after several times torquing I just used some blue loctite....prob solved!
Silato
128
73
Manchester UK
A tiny bit of movement in the suspension is normal. This is just the sag from the weight of the bike.If it's chattery, i.e something is loose, then you have problems.
It's really only slight when lifting and never noticed it in while out and the bikes in the air.
So with what you said I'll not worry too much about it for now. Thanks.
554K
