Hi All,
I have a 2019 Levo S-Works and last time I rode it I heard this horrible loud click from the cassette as if the drive train was about the break.
Took it to my LBS today to let them have a look and they said they adjusted the derailleur. I took it for a quick spin around the parking lot and it made the same noise.
The mechanic took another look at it and said the cassette was worn and this is not covered under warranty. Fair enough, I thought. I guess wear and tear is not covered. But, the bike only has about 1K miles and I lube the drive train before every ride. There is no "hooking" of the teeth or "valleys" that normally indicate a worn sprocket/cassette.
When I got home I discovered that a tooth was half-broken off on the second smallest cog and that this was the only cog the noise was happening on. The chain must be skipping a tooth.
Now I'm wondering if this is something that would be covered under warranty. This is a pretty pricey replacement part. Looks like a SRAM XG1199 is about $300USD
Should I go back to my dealer and show them the broken tooth? Would this be covered under warranty? Thanks!
