12 psi is really low but if it works for you all is good. I run my 2.8 tyres on my emtb and my normal bike at about 18 front 19 rear. It is more critical on the normal bike as too high it is bouncy and too low it squirms too much. Also Kcarbon I amy be mis reading but did you take your bike back to the dealer to have air removed from the fork?
Thanks for the clarification. Not wishing to come across as a know it all (believe me I am not when it comes to suspension!) but I would recommend getting a shock pump and doing the air in fork and shock yourself. It is no harder than inflating a tyre and it is useful to play with pressures to find what you like, just like with tyres.
. but I was not buying a pump as how I see it. once they are set right. your not going to need the pump.
Set up the new Levo tubeless today, 20 min job, just removed the tubes, popped in the supplied valves, sealant in and track pump up. Exactly as @ccrdave said
Another step closer to getting the beast out on the trails.
