Tips for re-sticking peeling Invisiframe edges
Dashfield
32
37
Bristol, UK
My LBS fitted Invisiframe to my new bike a few weeks ago and overall they did a really good job. But there are a couple of places where the edges are not stuck down and look like they’re peeling slightly.
It’s not bad enough to take back to the shop, I was just concerned about the edges getting bigger and causing bits to peel off over time.
Is there any way to stick these edges down? Should I try to get them wet or use a hair dryer? Or just cut them off to stop them from spreading?
My first ride on the bike was quite dusty so dust may have got under those peeling bits, which may be a problem when it comes to re-sticking them.
Any advice would be appreciated.
j3ayy
279
504
North Yorkshire
Hi pal. TBH once the air’s got to it they the glue will dry out & without putting some primer on the help stick it down it wont stay down. Probably only option is just to carefully remove the lifting part.
Dashfield
32
37
Bristol, UK
Thanks mate. That’s what I thought but just wanted to check before doing it.
578K
