Tell me what you think. If you do quote the topic please edit out the images and extra text. I was a bit loose with my spending and didn't include all my odds-and-ins when building. I am in the market for an OEM ebike, probably a Rocky Mountain Altitude or something with a Bosch drive unit most likely. Not entirely sure yet, which is why I'm here!
Frame:
2015 Chromag Rootdown
-135 x 10mm rear drop outs
-68/73 bottom bracket (external bearing cups)
-29 inch wheel size
-Integrated derailleur hanger
-180mm Megura brake rotor
Components:
Fork
-2009 Fox 34 Talas with Float spring set to 140mm
-203mm front Megura brake rotor
Cockpit
-DMR 35mm Stem 50mm length
-Spank Spoon 800 with 60mm rise
-One-Up components threaded Top Cap
-Magura MT5e with 3 finger 2 pin Higo connectors and harness
-KS 100mm dropper post with Topeak Aero Wedge saddle bag
-Ergon eMTB mens saddle with Topeak mounting clip
-DMR death grip lock-on grips
-RaceFace Chester pedals
Group set
-Box Two Prime 9 group-set for ebike (one click gear changes only)
-Box 9 speed wide range HG cassette
-Lekkie 40 tooth narrow-wide chain ring with Lekkie drive plate
-Shimano steps crank 165mm crank arms
Motor and controller
-Bafang BBSHD 1000w mid-drive motor
-SW102 display
-Main harness replaced with 2 pin Higo for Magura brakes
-52v 17.4 Ah battery with Samsung cells
-Left thumb throttle
-Shift sensor
Wheelset
Front
-IBIS 941 29" with Hydra straight pull aluminum 28 spoke hub
Rear
-eBay 36 hole carbon hoop with DTswiss 350 (12 x 142mm) Hybrid 36 hole hub with 2mm J-bend spokes
(281mm, three cross)
-Bolt-on 12mm to 10 mm step-down axle
-DTswiss 135 x 10mm hub endcaps
-29 x 2.5" MAXXIS Hookworm tires set up tubeless but running tubes
Accessories:
-SKS 70mm fenders
-Topeak top tube bag
-Topeak Aero Wedge rear bag
-Outbound Lighting downhill kit
-Amazon cheap bell
-Topeak rear USB light
-Kryptonite lock with custom made aluminum carry plate
Frame:
-29 inch wheel size
Components:
Fork
Cockpit
Group set
-SW102 display
-Shift sensor
Wheelset
Front
Rear
Accessories:
-SKS 70mm fenders
-Amazon cheap bell
