Tim29
Here a quiz i have for those who actually tune on there bikes suspension,
Keep simple answers. Example. If i turn the compression in 3 clicks does it affect rebound, if i open rebound clicker does it affects the compression.
Please don’t be shy, those that have no clew how to answer those would be helping me the most
1- rebound clicker what does it affect when you open it several clicks.
2- If i add air to fork how does it affect mid stroke comp and rebound.
3- If i add a volume spacer how does it work, what affects will it have.
4- coil over -If i install a stiffer coil spring will it make the bike stiffer or softer in first part of the stroke
5- coil over, will my rebound have any affect with a stiffer spring.
6- If i speed up rebound on front forks what will happen on jump
7- If i stiffen rear shock comp what will happen on a jump face/ take off
8- If i speed up front rebound will i put more or less pressure on front tire in turns.
10- front end is nervous at speed and feels like i have no traction. What do i do.
