Suspension air pressure
jcarlson9
35
16
la
How often does everyone here check or adjust the air PSI In their fork and shock ? I have a rail 7 with maybe 6 rides ane a little over 100 miles on rocky singletrack and it seems like my dampnig has gone off. Thanks.
Careyj1
86
77
Good question, I do think some fork and shocks lose air pressure over time. I am going to start checking more often, like once a week to see if I am losing pressure over a week.
Iggy_BBR
55
37
Bronx, NY
Usually if I feel or notice the suspension being less supportive. Also the night before riding some new trail, to double check the sag points. But in general I carry a shock pump, if I need to make any changes.
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
Months - everything I've had just seems to hold. If I haven't ridden for a couple of months, I'll check it.
9,991
Every single time I check the air pressure, it is ALWAYS lower than it should be! ALWAYS. So I don't check it, because I know that checking it lets air out and then I have to pump it back up again, which is hard work on a shock!
So I check the %sag instead. If that's OK, I leave the psi alone for another week/month/whatever. :)
GrandPaBrogan
⚡ eGeezer ⚡
Oct 5, 2019
1,329
2,070
New Zealand
Yep I agree. Every time we connect the pump, a small amount of air pressure escapes to fill up the pump hose, before the pressure gauge gets activated. Then we have to pump that air back in - just to restore the shock pressure to where it was before. Checking the SAG is the correct way as you mentioned.
Checking car or bike tyres aren’t as affected because those have large volumes of air.
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
There is usually a minor change with my tyres (1 or 2psi) - literally due to what the temperature is for that day.
576K
