Super Deluxe Ultimate Thru Shaft
Bomble
671
393
Yorkshire
Cheers, currently got a coil on got the chance to try the mentioned deluxe shock while the coil goes for a service.
dixie600mhz
174
160
Austin, Texas
Give us a review when done. Interested to hear what you think. The delux has been pretty good for me but I'm still close to pulling the trigger on a coil. My total riding weight is 210 lbs and I'm running 208psi with lots of damping to get is as plush as possible.
If I run higher psi it feels like I'm always getting popped off the seat no matter what damping I use. It's like you can't slow it down enough unless the psi is pretty low.
Bomble
671
393
Yorkshire
Will do, I’m also 210lbs kitted up too. My coil is awesome and will take some beating.
I had the same problem with the original reactive thru shaft shock, it seemed to blow through its travel and cause pedal strikes unless I ran a lot of pressure which then made it harsh.
dixie600mhz
174
160
Austin, Texas
Bomble, what spring rate are you running with the coil? I'm going to start a thread asking for total rider weights and recommended springs.
575K
