How to use this section. To the thread starter: Once you are satisfied with the answer that youve been given, click the Trophy on the left hand side of the message. This will rate this answer as the 'Best Answer' and will change the question status from 'Unanswerd' to 'Answered'. All members can also upvote an answer with the 'Up' arrow, this will help identify the best answer.
The only critical area on a bike as far as type of grease is concerned is the freehub. Most bearings on modern bikes are cartridge ( sealed) types so most applications for grease on a bike other than the freehub are assembly. Any general purpose lithium grease is fine for that except where the surface is carbon and then you need a carbon assembly grease.
Different types of grease are made to cope with areas that are subject to heat , contamination or high loads. None of those are issues on our bikes except for water ingress......hence the use of a lithium grease.
Freehubs are different whether pawl or ratchet simply because they need greases that lubricate without causing clogging. These greases are typically a lot thinner ( pawls) or with high adhesion ( ratchets) properties.
So if its an ally bike you really only need 2 types of grease. A general purpose lithium grease for virtually everything except the freehub. For the freehub use DT Swiss general purpose grease for pawl type or DT Swiss Special purpose grease ( red in colour) for ratchets.
There is a need for a different grease ( e.g. SRAM Butter) if you are going to service forks/shocks. Follow the manufacturers recommendation for that.
