Stunlocker licensed installed and indeed quite happy so far on first trial run tonight on some biggish bike park jumps tabletops etc... What I'd like to know on my android version is:
- What is roughly optimum setting, I've set to US and wheel circumference 2200mm-27.5 on drop down list... the % adjuster further below only goes to down -5% which I did.
- Was recommended to reduce wheel size to 62%, does this equate to a certain wheel size in mm I should do...what is the % adjuster below for then?
- Will not be changing any other settings...only need an increase in speed to clear gaps and jumps.
