STunlocker question
Dave_B
1,467
1,593
Newquay
can I set eco mode to be low eco setting, trail mode to be medium eco setting and boost to be normal trail mode?
I used e-tube to change eco to low eco and got some impressive range numbers today, so want to setup my eco, trail and boost modes as per above. I can't see how you can do this in e-tube, so winder if it can be done in STunlocker?
20,791
No.
You can set eco to be whatever you like, it's far more adjustable than with etube. You can even lower the overall power of the whole motor and make it like an EP8 if you like.
Trail mode is dynamic, so it self adjusts and does things on it's own and is constantly changing the power and assistance as it thinks is necessary. You can set some starter settings for it though.
Boost can't be set to Trail as trail is the only dynamic setting. But you can lower the boost settings in various ways..... so it's less boosty ! :)
I think I used to run eco on 15% from what I remember, it's a long time ago :) Which was still really usable.
554K
