Stunlocker app issues
Mike Hawkins
AUSTRALIA
Stunlocker, my first use to change front chainring size and it Corrupts my firmware ??? Has to be sent back to Shimano for hard reset. Not happy ?
iXi
424
321
Brisbane
Just log back in and change it back to what it was and it usually comes good. Thought I'd bricked mine when I changed the front chain ring and it e10 errored.
Mike Hawkins
AUSTRALIA
E010 is all it gives me regardless I’ve what I do !! I haven’t tried changing it back!! Will try it ! Thank you ??
StuE
282
298
Leeds
@vadII I think you added the chainring size change due to user requests, but I guess it doesn't work properly. Is it worth removing the option from stunlocker for now ??
I highlighted this a when it was first added, it really needs removing,I found that if you turn the bike on and immediately connect the app you can connect before the e10 error appears then change the chainring size to either 34 or 36 and all should be ok at least it was on mine
552K
