Stunlocker and Shimano E8000
lightning
715
410
l want to change the wheel circumference on Stunlocker, but l've updated the software to the latest version.
l only want to get the speedometer reading correctly as currently it reads about 5% high, so if l reduce the wheel circumference 10cm that should fix it.
l can get into the wheel circumference menu and change the value, but what happens if l press "update" if l've got the latest firmware installed.
Will it work? l am worried it might reset it to the factory settings!!
As it's already set 10cm lower than standard (the speedometer was reading 10% high)
Singletrackmind
468
424
San Diego, CA
I would email the guy who created STUnlocker software. I've reached out to him a couple times via email and he always responds back.
20,691
There's the thread too, I think it's mentioned in there. Have you checked the manual, that explains it too I think.
545K
