Straightening a wheel....
Beatn1K
120
49
Perhaps I need to post this in the Newbie thread, as I feel like its probably where I should be...!
..but here's the thing!
I recently picked up a buckle in my rear wheel. It's a DT Swiss 27.5, as fitted as standard on my Merida e160 900e (2019). It was annoying me once I realised it was there..which wasnt until I went out to ride some taramac betwwen sections locally.
So I resolved to have a fiddle with the spoke tension and such. I thought id made a significant impression on the degree to which the rim lurched over evevry revolution. Riding it, it is much better but still annoys me...!
Do I just suck it up ? How do you cyclists get your kinks out..? :D
Perhaps it's worth taking apart and straightening the metal hoop and the relacing it..? It's not for fun though...
They arent cheap so buying new isnt really practical. Its got <1K miles on it...hence the notion I need to just suck it up...? ( I dont notice on the trail..)
I suspect its too much to use spoke tension alone but Im no expert TBH - plus i worry that I am loading the spokes unevenly and setting myself for catastrophic wheel collapse...?
I am a newbie to this Bicycle stuff. I am constantly remarking on how 'fine' its all been engineered...everything wittled down to the smallest,lightest "waffer" thin dimensions...A new wheel will do the same thing again wont it ?
Beatn1K
120
49
A lot of dry wheel building info for the nerd....cheers....!
Having worked on "bruised" MX rims any number of times...a slightly different issue, granted, I know that the rims are extremely resistant to being pressed back into shape...
Looking online- maybe a replacement rim, new spokes and nipples is the way to go..
Realising that you probably cant fully compensate for a bent hoop with truing alone...!
Anyone kow what the rim type Id want for merida..?
Maybe I could try this sucker...? DT Swiss HX 581 27.5" Hybrid Disc Rim | Rims 27,5" Shop
although, honestly, it looks like this one will have more strength in it if the weight rating is anything... DT Swiss HX 531 27.5" Hybrid Disc Rim | Rims 27,5" Shop
Also- what do they mean by "incl : PHR washer and DT Pro Lock Squorx Pro Head nipple" ..?
cheers
Gary
Old Tartan Bollocks
10,496
10,702
the internet
If the actual rim is bent you'll never make it true again without having uneven spoke tension.
This at best means a weak wheel. At worst a dangerous wheel.
You're actually best truing to even tension and living with the bend.
But you really need to replace the rim.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
A nipple washer is just that. A washer that sits below the nipple. Not all rims require them. And even then they're not always essential.
Squorx nipples have a specially shaped pretusion at the bottom and can be turned from underneath the rim with a Squorx niple driver.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
You need a replacement rim with similar ERD measurement to the original if rebuilding with the same spokes
Beatn1K
120
49
Expensive toys these ebikes...! I agree with you.
I needed it confirmed really....
Gary
Old Tartan Bollocks
10,496
10,702
the internet
not really.
you can buy a rim for as little £25 and re-use your original spokes/nipples
553K
